Re: Hazard warning switch
Is it the swwitch on top of the steering column, or the later ones in the dash?
Strikes me that if you have replaced it once and the new one doesn't work there is a fault somewhere else in the circuit.
If you remove the glove box the flasher unit is located there. This could be defective, or, perhaps someone has tapped into the hazard switch circuit looking for a permanent live, or chopped around with the cables for a car alarm?
