I have had problems with smoke on start up ever since I got the car, and unfortunatly didnt get the turbo replaced when I could have under the warranty - the garage just cleaned the breather tubes and it was a bit better for a while, if only I had known about Saabscene then!
Anyway, I have been planning to get mine replaced for a while but last Novemeber had all the latest PCV mods done to see if that would clear it - 'fraid not! So I bought a turbo, gaskets, studs and some incredibly expensive nuts (ÂŁ3 each iirc!). And then they sat in the corner for several months, I guess I was saving up for the fitting!
Then at the weekend in the evening it made some funny noises under acceleration, but being dark I couldnt see the reason why! Next day driving around was like being in a fog! So I was lucky enough to get the car booked in at the specialist I use and they replaced the turbo yesterday.
They said it was 4 hours labour so I limped the car down there in the morning - it was not too bad smoke wise when on the move but once or twice on changing up / down there was a terrific plume of smoke, enough to make the cars behind swerve around, poor things. Then to make matters worse I had to queue as traffic merged into one lane and the smoke was TERRIBLE! I thought I wasnt going to
make it the next mile or so! But luckily we started moving again and the cars behind me were almost visible!
On arrival, they said that they would flush the intercooler out as that is where any debris / gunge etc would end up and could cause the new turbo to fail within a few miles. Obviously they would also change the oil and filter.
Anyway the car was ready later on yesterday and they gave me the old turbo, it was absolutly shot to pieces; lots of chunks out of the blades, but the worst bit had to be the "play" on the actual turbine shaft - it moves as if it is not even held in on any bearings or anything. They also reported lots of gunge and stuff in the intercooler so it was good that they had cleaned that out.
So I drove away in a car that after nearly 4 years does not smoke, and has a good deal more poke
so I wish I had done it earlier! And the bill was pretty reasonable, about ÂŁ160 in labour + oil, antifreeze and the odd gasket that I hadnt supplied. ÂŁ225 all in + the price of the turbo.
And at last I can use this
