Cooling Fan
Tags
cooling fan
1 reading
1.6K views 3 replies 2 participants last post by  Guest
#1 ·
I have a '95 9000. The cooling fan comes on as soon as the ignition is turned. The relay is in good order so I think I need to change the thermostatic switch. However, it is not located anywhere on the radiator (as shown in the Haynes manual). Can anyone tell me where to find it, please ??
#2 ·
it will be on the rhs of the block (if looking at the front of the car)
Inside the casing where the top rad hose attatches.
WARNING !!! Make sure the cover is on the gearbox inspection hole or block it up.
I did a "Quick" replacement of said thermostat a few years back - and in my hurry I dropped the bolt from the thermostat housing straight into the gearbox, Had to remove the whole box (not happy)
Damian
