Replacing Fog Lights - any info
1.6K views 2 replies 2 participants last post by  kit-kat
#1 ·
Had a look about, but don't seem to be able to find a guide or anything about replacing fog lights - is this something that is easy to do?
What tools are required? any info appreciated, any links to guides online, etc.
If I can do it myself I'll be doing that and at the same time get me some amourfend to replace both fogs which have suffered cracks in the last month!
Any help much appreciated!
CH
PS anyone know if tightening the handbrake is an easy DIY job? - help appreciated on that too!
#3 ·
Hi c_hawkins welcome to saabscene
Both the 9-3 & 9-5 fog lights are interchangeable!!
to remove just pull out the black plastic grill next to the fog light to expose the 2 nuts holding the fog light in place! would recommend WD-40 both nuts (10m spanner) before you start as these where well rusted & seized on mine ended up having to hack saw through one!
then remove wiring plug & rubber grommet from behind & that's it! enjoy
