Anyone have any experience of 'backing off' the hydraulic cam followers ? I've recently had the head skimmed on my '95 9000 lpt ( Corroded core plug = overheating = head gasket ) and had the valves re cut while they were at it. ( 236k miles )
On re build I now find that the engine starts fairly easily but only runs on three cylinders ( No 3 is down ) and gets rougher as it warms up. My guess is that the ecu via the lambda sensor recognises the unburnt fuel from No 3 and weakens the mixture till the other three won't run. If I leave it to cool for 10 minutes or so then it starts OK.
I think that the recessing of the valves means that one or more of the valves in No3 is not closing fully and so I need to let some of the oil out of the cam follower to allow this to happen. Is it just a case of whipping off the camshafts and removing the buckets ? Is there a 'valve' that can be depressed in the hydraulic tappet whilst maintaining pressure on the tappet ? Haynes as per usual is blank on this.
Paul@Kippen.
Paul@Kippen.
