Couldone some tell me where the earthing point on the front crossmember of my 85' Saab is located? If you could direct me to a diagram or picture that would be great. My wipers cause the engine to stall. Thanks, Hank
It's under the right hand side of the radiator near where the battery sits. In my 1983 900S there is a large braid and lots of other earth wires from various places around the engine connecting to it. Probably a wise idea to completely renew or at least clean it now and then to ensure the electrical contact between the chassis and the braid, etc. are maintained.Originally posted by Hankster:
[qb]Couldone  some tell me where the earthing point on the front crossmember of my 85' Saab is located?  If you could direct me to a diagram or picture that would be great. My wipers cause the engine to stall.  Thanks, Hank [/qb][/b]
In addition to steel-wool, clean all the grease and oil away from the surfaces which will make the electrical connections using your choice of degreaser. Most people use WD40, RP7, or similar. Removing grease/oil helps ensure the contact resistance stays low for as long as possible but the earth points should be checked regularly but only need work if they give problems or show signs of corrosion.Originally posted by xassh:
[qb]basically, disconnect your battery's negative terminal, unbolt the earth point, clean with steel wool and reassemble
also, check for any damage to wires and repair as necessary.
the ground that you are looking for is most easily located when standing on the right side of the car, looking down past the battery, below the radiator. it is a few inches towards the center of the car from the radiator drain plug. [/qb][/b]
