I have this problem with my 1999 Saab 9-5 where it starts when it's completely cold, but as soon as it's warmed up, and I shut it off, it won't
start again for days. Just cranks away, but never starts. So the starter seems to be working, and the ignition. I replaced the crankshaft
position sensor since that was the most obvious cause, and thought it was fixed for a couple of days, but it isn't. Still doing the exact same thing. I'm wondering if it's the DIC. Or perhaps the Camshaft Position Sensor. I think the camshaft position sensor is built into the DIC on this year. Confirmation anyone?
- Could it be the DIC cause this sort of problem?
- Even though it's a brand new crank position sensor, how exactly would I test it with a voltmeter?
- I've heard of a starter that is just starting to fail displaying similar symptoms also, though I don't think exactly the same. When a starter gets warmed up and then you turn the vehicle off and crank it again, it cranks slower than it should and the vehicle doesn't start. If you let the starter cool down, it
cranks at normal speed and the vehicle will then start. Possibility? Though I've not really detected the starter sounding overly slugish when cranking ever, even when hot, so I feel like this is a more remote possible cause of my problem.
