APC/Turbo Gauge not working
1 reading
4.2K views 1 reply 2 participants last post by  Trollbooster
#1 ·
I'm running a 1996 Aero with 96,800 miles. Today I noticed that the APC/Turbo indicator is dead center on the dial and doesn't move. The turbo works and the engine runs fine. I haven't checked anything yet (ten degrees and no garage). Any ideas? Thanks.
#2 ·
Follow this post.
It will, most likely be one of the vacuum/pressure hoses has become disconnected under the bonnet (Hood, to you guys ) Easy enough to spot anf fix even in sub-zero weather.
if the end has split, you should be able to shorten it ÂĽ" until the spring, when you can change it for a new one - try the silicon hose mentioned on these pages.
