Hi Everbody.
The situation:
1. Strange curry/coolant type smell.
2. Misty windows for no apparent reason.
3. Loss of coolant (checked all hoses/radiator/water pump etc and all are fine)
There is also a near constant drip from an outlet leading from the bulk (false) head. The outlet has a sort of rubber flap over the end.
I gather from these symptoms that my heater matrix is leaking.
I am going to attempt to replace the heater matrix myself and I understand that its not the most straighforward job. But with all the helpful previous posts with associated links I will give it a go.
My question: Due to work commitments I have been unable to even have a look to see what needs replacing and I was wondering what else I should buy, other than the matrix itself, to ensure that I have all the parts (ie, hoses or seals or anything like that) that I may need to replace when I start the job?
I was going to buy the matrix from GSF or ECP. Are the ones from here ok?
Thanks everbody
9k
The situation:
Thanks everbody
9k
