refilled my wahsher reservoir today and now it doesn't work anymore. Only washes the headlights so I know the pump isn't defective. Any one have any ideas on how to check the tubes "easy" before I tear down the entire system ?
Easiest first, check for fluid to hood at cowl pannel.If yes Check check valves on hood and nossels.
If no , remove the right lower panel below washer jug, either has A BAD 3 WAY CHECK VALVE OR THE HOSE IS OFF. A lot of times oil or P/S fliude leak will destroy the hose that runs half down the inner fender to the jug.
It was the hose who came off...Had a hell of a time removing the plate though, couple of screws had to be removed with a lot of improvisation ! But in the end it all worked out . Thanks !
