Don't want to scratch the bonnet trying to get it off, so does anybody know the best way to remove a screenwash jet?
changed the one way valve (got cheap one from local car store) after much changing around with the direction, now getting something out of the jet (LH side, RH side working no probs). tried cleaning jets with bit of fine wire but no more output from LH jet.
Now thinking I need to remove and clean through with air line or similar.
TIA,
Pete
I'll add my comment because I couldn't get anything like sensible pressure from my jets.
I tried, the valves, a new pump, all sorts, tried removing and cleaning but still no joy.
It didn't seem like there wasn't enough water getting through but rather too much on mine and thus no pressure to spray but just a large glob of water that had no force.
In the end I just whacked in a pair of twin jets from Halfords. Worked a treat.
David.
