Paul D,
Here is an extract from an article that appeared in the States about Eklund's Pikes Peak 9-3 Viggen, written after he'd come 2nd overall and 1st in class. The article is probably too long to post here and anyway there is the stuff about copyright so I've rearranged the text a little and this is just the stuff about the engine. If you want I can e-mail you the whole lot?
Tommy Karlsson, of Trollspeed, Trollhattan, and Eklund himself tuned the turbocharged 2.0 litre four-cylinder 16-valve dohc engine. They started with a stock block and head. The block has been reworked and now features Nikasil cylinder liners. In addition to being perfectly round and greatly reducing friction, the liners also allow an individual cylinder to be repaired if necessary. Omega supplied the pistons, and "really special" connecting rods were made in Sweden. An especially strong oil pan was fabricated out of 60mm aluminium for the dry sump-oiling system. Special baffles for the many hairpins and extended uphill runs at Pikes Peak were fitted to assure good oil scavenging. The pan also serves to support and strengthen the block.
Six of the ten head bolts go all the way through the head, block and oil pan to provide tremendous clamping force and make the three pieces act as a single unit. With the Garrett turbocharger feeding the engine an intercooled charge at 42.8lb(3.0 bar) of boost, things had better be strong. The engine puts out 750 bhp at 8000 rpm and 518 lb-ft of torque at 6500 rpm-at sea level using special Elf Racing fuel.
