2007 9-3 linear convertible
Long backstory short... had the dreaded "steering lock failure" message... swapped out the ISM and fixed... however when I was following instructions to do this I got to the point half way through where I "should" have been able to drop the ISM out by simply pushing the four clips in... didn't work... wouldn't budge... so I ended up having to take the whole section apart to remove it (when i finally got it free I found one of the clips was actually mangled so badly i had to break it off to free the module) anyway... the point is that after disaassembly I was left with a floating pipe (pictured) that was not mentioned anywhere in the instructions I was following.
53053
53054
I assume it is a feeder for the aircon? but you know what "assume" means... so I was hoping that someone could point me to 10 what it is and 2) where do I attach it back to because 3) yes that is a very wet carpet in the second picture.... it leaks like a sieve...
Thanks in anticipation
Administrator
antenna cable for phone kit..
