1 - 9 of 9 Posts
You looking for the 6cm2 ones?
mitsubishi 18T
Volvo S/V70R
some 2.5 T volvo's
18T - B5234T4 250hp 1997-1998 only S/V70R man FWD/AWD, 275/60 wastegate and straight outletform turbine.
18T - B5234RT 250hp 1999 only V70R AWD, 4-vxl aut, 300/70 wastegate and angled outlet form turbine.
mitsubishi 19T
some 2.5T volvo's
19T - B5244RT 265hp 2000 endast V70R AWD, 5-vxl aut, 300/70 wastegate and angled outlet form turbine.
Garrett GTBB30
Not sure, one of there Ball bearing models capable of 500hhp.
see also http://www.melett.com/pdfs/MHI/Applications.pdf
GT30BB is strictly an aftermarket option. Count on 1,000 euro plus BTW (Dutch VAT)...
The Volvo fitments all have a 7cm2 exhaust housing, whilst the TD04HL15T on 9-3/9-5 Aero models is a 5cm2. AFAIK swapping out exhaust housings between the two is a straight swap, but then you'd be left with a considerable imbalance between turbine and compressor flow characteristics.
The Volvo turbine housing OTOH uses a different sealing method on the flange towards the exhaust manifold (metal 'ring' instead of the Saab 'cold' gasket fitment). Still, fabricating an adaptor for that and the different bolt patterns whilst porting your exhaust manifold to match the 'hole'in the Volvo's exhaust housing seems a more promising way than trying to mix the Volvo turbo with the Saab exhausthousing.
1 - 9 of 9 Posts
