I haven't removed the liner yet to check, but as far as I can tell my water pump is leaking around the pulley shaft.
From a quick search, this looks like a nasty job if you have A/C (I do), and may require dropping the downpipe. Is this right?
I am wondering how this relates to my rattle from the belt/chain area. It could be the source of the rattle - although I'd normally associate a knackered pump with a whine, not a rattle.
It occurs to me that the rattle could be from the tensioner/damper. I seem to remember people saying that problems with the damper can cause a vibration/harmonic in the belt, which can destroy bearings on the pulleys - with the water pump being the main culprit. Does this sound right?
The rattle did appear at around the same time as the coolant leak.
Is there any way to check the tensioner/damper once you have access to it? What about the other pulleys... just spin and check they are free and have no play?
Any comments or advice appreciated.
