Hi all,
I'm on the verge of ordering a ShurFLO 8000 series pump for my water injection system, but after perusing the websites of folks that have built water injection systems around them I'm still unsure about one thing - which fittings should I order from Aquamist in order to fit the water injection hose, and which would I need to find elsewhere? The way I see it, I would need two 4 mm hosetail (that's what the Aquamist nozzle I have, has) to 1/8"BSP adapters, then two 1/8" BSP to 1/2" BSP or whatever the ShurFLO uses, to connect the hoses from the washer bottle and to the injector nozzle. Am I correct in that assumption, and are the fittings on the ShurFLO pump indeed 1/2" BSP or something entirely different?
