Tried going through the searches, but can't seem to get my head round the various threads. Hope somebody may be able to help.
Was trying to see if wastegate actuator was actuating(putting hand down between cyl block & turbo & putting fingers on actuator rod and turning throotle cam) and noticed at the RH end of actuator rod that it was not connected to anything (rod is round but end is flat with approx 5mm hole at the end?) nor did it move when revved beyond 4krpm (by ear).
What is the likely result of this? The car, as mentioned several weeks ago, here, does not seem to have as much go as it used to have after 3-4krpm and at the time was wondering if it was the almost undetectable Bosch DV.
ANy thoughts greatly appreciated.
Cheers,
Pete
Cheers,
Pete
