Here's the situation, 93 LPT with wastegate stuck fully closed (car tries to accelerate like crazy and overboosts -which is horrible. Engine uses too much coolant, despite head gasket replaced 4 months ago; had a look underneath at the Turbo and I see white 'crust' apparently seeping out of the exhaust side of the turbo around all joins. Including where the wastegate arm comes out of the turbo. This must be cooked anti freeze; and probably what's causing the wastegate to corrode/seize. How is this getting into the exhaust? Is it possible that the turbo water cooling system has started leaking into the exhaust side of the turbo? I thought it was quite separate.
Any thoughts or experience of this problem?
Many thanks
George
Many thanks
George
