I think you will find you have to remove the off-side front wheel and the wheel-arch lining to get at the problem . IMHO you will no doubt find it is a failed non-return valve in the pipe line . It is a plastic tee piece with a venting hole . You will need to get a new one before you start the work.Hope this helps.Had to fix mine; same year and model a few years ago.Originally posted by peter9000:
[qb]is this an easy thing to do or not,because it looks awkward to get to.thanks
Peter.[/qb][/b]
