I am in need of a Dizzy for my 900T 16v Convertable 1987 the part number on the side is 0 237 507 007 if anyone can help?
Discussion Starter #3
Hi Rob
Sorry been really busy, did you manage to find one? Let me know on here if you have, promise to check everyday! Also do you have a peice of the loom with the oval plug that plugs in to the Hall sensor on the side of the dizzy that I could splice in? If you have I will give you a call.
Steve
Hi Steve, I did find one but the last three digits were different, it dit come of a t16, 88/89 model year don"t know if it makes any difference, will have another look as its back in the garage will also see if theres a piece of loom, all the best rob.
Discussion Starter #5
Hi Rob, thanks for looking, I think it will fit so long as it has an oval plug socket on the side pointing towards the front of the car when in the fitted position, the only difference will be the rotor arm shaft size. The plug part of the loom obviously needs to fit the distributor, many of them have a rectangular plug and socket but don't fit this particular year model to my knowledge. Let me know at your leisure and let me know how much you would want for the bits if you have them.
Best regards and thanks for your help
Steve
Hello Steve, had another look and the loom socket is more rectangular than oval with three pins, also have a spare loom with plug, I also have a couple of 8v dizzys the loom socket on them is oval, are you sure your car is 16v, if you let me have your email I can send you a couple of pictures, all the best rob.
Discussion Starter #7
Hi again Rob
It is definately a 16v, it is the original dizzy too. My email is [email protected] if you have the time to send me a pic! Perhaps you could let me know the number on the side too. Many thanks for taking the time to help me.
Best regards
Steve
