1995 Saab 9000 CD (2.0 non turbo). Battery is Bosch Silver (1 month old).
I turned the ignition on (but did not turn the engine over), after a few seconds there was a small/dull bang from the engine compartment and smoke appeared from rear of bonnet. Turned off the ignition and lifted the lid to see smoke coming up from under the inlet manifold / oil filler, which soon cleared. Checked fuses - all OK. Car starts and runs OK. The ignition light is on when it should be and off when the engine is running. Voltage measurements with voltmeter across battery and readings from dashbaord display:
Ignition on: Battery 12.5 / Display 12.0
Engine idling, revving or under load (lights etc) (NB it does not make much differnce) : Battery 14.4 to 14.55 / Display between 8.7 and 11.1 (NB -once the car is running dash display stays at the same figure no matter whether revving or under load).
I suspect the voltage regulator. Can anyone confirm? And any ideas on where to get a new regulator, the alternator is Bosch 0 123 320 039.
Any advice gratefully received. Just the way to start the week :-(
Thanks / Stewart
Thanks / Stewart
