1 - 8 of 8 Posts
Administrator
you need to cut and weld the rear shocks as the top mounting is different in the vec c..
Discussion Starter #5
thanks guys, will i need Vectra 3.0CDTi V6 coilovers or will the CDTi 150 ones fit fine? The ttid is only very slightly heavier than a tid 150
Hi I'm new here have an aero 93 210hp... getting the jomcoilovers and obviously gonna use the standard rear shocks, does anyone know if the jom rear springs pop straight in with out any problems? Thanks first saab new to this lol
I thaught the coil overs came as spring and shock as one unit .
So you are just putting coilovers on the front ?
If so rear spring
Require the rear trailing arm to be unbolted
One bolt then leaver down on the arm then the spring comes out .
Replace top and bottom rubber mounts as they are weak points .
Safety, use axel stand and a trolley jack to lift the rear arm back into place .
1 - 8 of 8 Posts
