Hello all... had my tonsils out last week (ouch, but that's another story), last night took my baby out for a spin for the first time. First bit of mild throttle (nowhere near full boost) and the boost gauge stopped working, very audible hiss in the cabin when on overrun (goes away when you're on the throttle).
I had an inspection of the pipes, starting at the T junction by the battery... it appears there's a big crack in the pipe right by the T junction, on the section that appears to go up to the inlet manifold.
I've bought a section of silicon hose from elkparts however I shouldn't think that'll be here before monday/tuesday. The car appears driveable however the only way I can get rid of that irritating hissing is to disconnect the section of pipe that goes to the boost gauge. Silly question I know but will driving the car in this state have any negative effect? It seems driveable (takes a bit longer to settle down to idle though - or am I imagining it?) but thought I'd check. Need to drive a 300mile round trip on sunday from london to hereford and back, always worth making sure
any advice gratefully received!
ps related to this, when I come to replace the piping, I think the one that goes off into the bulkhead towards the boost gauge will need replacing too. The rubber (or whatever it's made out of) feels very solid and not as bendy as I think it should. How far into the bulkhead does this tube go? Is changing it easy? Is it one piece of pipe all the way from the T-junction up to the pipe? I could check for myself I suppose but it's a bit cold and I don't quite fancy dismantling the car just yet if I can help it Thanks!
