I will be driving my 1994 Saab CS on a 1000 km trip in a couple of days. However, today I was looking between the motor and the firewall to check the gearbox linkage joint when I saw a sensor hanging in mid air.
I can't find where the sensor should be placed. The shape and size of the sensor is exactly the same as the one which is installed into the lower half of the engine block underneath the exhaust manifold. The mounting bracket is the same too and wiring is enclosed in a black sleeve.
The car has been running for at least the past month without the sensor being mounted properly and I don't know what it's function is.
I would be pleased to be advised where the sensor mounts and what it is supposed to do.
