apparently the Aero wastegate actuator is stronger than the rest so if it is working properly it should be ok.
If memory serves correct, your aero is a stage 3 maptun?
I went with a Forge unit for my 9000 LPT Stage 2. They can be serviced and you can choose your spring PSI to suit your boost
I'm looking at getting a forge actuator for my Aero as I think the original part is on its way out. What boost pressure should it run std and what should I get the forge one sprung for?
I have a full 3" system on the car now and will get the stg 3 ecu in due course....
