Hi all. I have a totally standard 2010 93 1.9td vector sport cab and I am wondering if it is possible to upgrade the candles that it has for full and high beam.
Any help welcome.
Hello shiffa , I know what you mean by candles they are not of the best .
Osram nightbreaker , is good and I used them .
Also I adjusted the headlights up slightly ( mine were set stupidly low )
and I polished the headlight glass with a kit I got from Halfords made by Megulars,
all 3 of the above made a 100% difference
they always say , see and be seen , they could see me but I could not see the road that's how bad mine were before hand .
Discussion Starter #5
Just for reference, I ended up going for the Phillips X-treme Vision and I am really happy with the results. Much brighter beam than previously.
My 2004 93 Arc convertible also had very dim lights. I polished them to almost absolutely clear, which helped some, but not enough. The problem turned out to be that the reflector chrome inside had bubbled and gone gray. The only solution was new headlamp assemblies. Expensive, but problem fixed!
