Iv'e been in touch with Southendsteve about his turbo parts off his 2.3 Carly.
Would the turbo/manifold ect fit on to my 2.3 auto 91?.
But will the pistons be the same or are his high/low compresion job's,if I need the piston's there's no point but if not well.
The turbo and manifold will fit but normally the turbo cars have lower compression pistons. You will also need the APC module, control valve, knock sensor and boost pressure sensor from the turbo car. Your car may be pre-wired for these components but I wouldn't bank on it.
