1 - 12 of 12 Posts
Out of interest, does anyone have any information on the reasction time of say, a B234R engine re. turbo spool up.
Say I floor the throttle at 2000rpm, how long does it take the for the boost to build to the spec. level?
This time will vary lots depending on engine and on the rpm selected but someone must have done some anaylsis at some point?
IIRC Vigge was running a stage III setup?
A stock Viggen also builds boost very quickly. Full boost can be available as low as 2,200 rpm. Vigge was at about 2,400 in that vid I think. The freeflow exhaust helps a great deal at low rev spoolup.
The Viggen's cams, despite being bad powerwise, are good for spoolup, as is the tighter 05cm exhaust housing on the TD04 turbo. Both of which combined make some very high EGT's for a stock engine, but that's why it uses Nimonic valves.
Dubbya~
Adrian, that is correct the car is stage III modified in that video.
Here is a link to an old video of mine.
Viggen with SP stage I
Stage I video
Dont see much difference to the spool up time between stage I and III.
Some day soon I will make a new video. Spool up is alot faaster with the better flowing IC
Originally posted by Vigge:
[qb]Spool up is alot faaster with the better flowing IC    [/qb][/b]
*coughs* I think that I remember having a BIG debate about this a few months back. Huge thing about whether a big intercooler caused lag, or reduced lag.
I feel the need to pipe in and say I TOLD YA SO! Obviously it may not be true in all cases. But the Viggen's stock unit is tiny, and I had a feeling a better flowing one would reduce boost lag. It appears I might have actually been right about something for once! Dang, time to get out the champagne!
Dubbya~
[qb]I feel the need to pipe in and say I TOLD YA SO!              Obviously it may not be true in all cases.  But the Viggen's stock unit is tiny, and I had a feeling a better flowing one would reduce boost lag.  It appears I might have actually been right about something for once!  Dang, time to get out the champagne!
Dubbya~ [/qb][/b]
If you think of it this way:
Custom IC (like mine) has about twice the volume compared to stock IC, but it will flow 4 times better with same pressure drop. Logically thinking the better flow will compensate for the extra volume.
Right Vigge! But that's exactly what I said and no one believed me! *sniffle*
The volume of air in the intercooler isn't even equal to the volume of air your engine takes in on one or two rotations. I never understood why people thought a large one would cause lag. *shrugs*
Dubbya~
1 - 12 of 12 Posts
