I have just broken the first rule of car maintainance - I've disconnected a wire without noting where it came from
On an '89 turbo, under the steering column, there is a plastic turbo overpressure switch, with two wires connecting to it. Unfortunately, there are three terminals and I don't know which to connect.
With the unit on the bench, there is continuity between terminals 2 and 3. I've tried blowing down the vacuum tube to simulate turbo pressure but I don't think I've enough lungpower - the continuity doesn't change, anyway.
The query is, should there be continuity normally, or should I have one connector on terminal 1 - if so, where does the other cable go, 2 or 3?
If it helps, the Saab part number is 8594632, and both wires are green and white.
I would appreciate any help asap as I would hate to misconnect it and fry the APC box or something.
Thanks in advance.
Thanks in advance.
