first of all happy new year to all.the turbo on my lpt has changed from whistling to making a noise like an owl,if you know what i mean ,and as i have fractured my elbow i cant realy investigate. can anyone help. oh the exhaust is blowing after the cat.... could this be related. all the best for 04 to all sabbers.
Mine does that a bit when it's cold, usually occurs under 1/2 throttle. Mine's been whistling for 18 months, it did appear to be gettting worse but recently it's seems to have declined.
Some people describe a noise like a distant police siren, is this similar to yours? I believe that this is a common indicator of worn bearings in the turbo, but the problem can hang around for some time until it becomes terminal.
HTH
the noise is there when you accelerate,the normal whistling sound has changed to a kind of whoooo,which stops when i ease off throttle.the car runs fine by the way.i was thinking maybe a loose connection somewhere.
