1 - 1 of 1 Posts
Hi All,
many have done an EGR delete (while remapping) and have put a blanking plate between EGR body and the pipe to the manifold.
My EGR was deleted (ECU) due to premature soot build up because my swirl valves had been removed.
A while ago I decided to remap my 180HP engine. My tuning specialist checked some numbers with a esid2 and noticed there was some negative pressure in the inlet manifold. The EGR remained 3% open so I have to install a blanking plate.
He told me there is a kit containing 2 plates, one for the EGR itself and one for the tube entering the manifold. Unfortunately I can't find the plate for the manifold. He told me, if I want to keep the connecting tube (visual inspection MOT), I can cut off the tube part that's inside the manifold. It would improve the airflow inside the manifold. By keeping that pipe, the original O-ring would still be in place to prevent air leaks. Where the blanking plate is installed, I will use HT instant sealing on both sides of the blanking plate.
Anyone of you guys have used this workaround? Opinions?
Automotive tire Drinkware Pottery Gas Serveware
Gesture Font Rectangle Circle Fashion accessory
Wood Safety glove Gas Auto part Plant
1 - 1 of 1 Posts
