Hello everyone,
Since I had many troubles with my TTID (and especially about pollution, EGR valve or DPF...) I ask to myself : what if I disable the EGR by the ECU ?
I see that many threads (on ECU forums) are about ECU files with EGR off, but I don't know what users though about the use of the car after this modification.
Some of you guys could tell me if it's a better car ?
What about the pollution ? (not only in measured in Technical control centers, but visually at the exhausts ends too).
A "simple" remap with EGR Off is enough, or install a blanking plate is recommended in addition ?
A DPF-off is it recommended in same time ? Or is it possible to have only EGR off without issues ?
I had the DPF gutted and deleted which made a massive difference to the ownership of the car. My EGR is still present but it’s only a couple of bolts and a quick clean, but I’ve not had a problems with EGR.
DPF removal is illegal in the UK but car passes emissions test each year:cool:
Thank you for your feedback ! ;)
It's illegal in France too... but if there is no visible difference from under the car... it's ok.
If we delete the EGR, maybe the DPF will less clogged ? no ?
How clean are your exhaust ends since your DPF off ?
If I use regular Shell Diesel then over a week it will get sooty, but a wipe with a cloth gets rid. If I use Shell V-Power diesel it’s clean for ages doing the same commute route.
