Can anyone please help?
I need to fit a towsure towbar. Will wiring the electrics to the socket provided in the back affect the bulb failure monitoring system?
Do I need to remove the rear bumper?
Is it easy?
Thanks for any help anyone can offer
There is a trailer connection socket under the rear LH light cover. I connected to the wires going into the socket with scotchloks as the Saab connection cable is around £60! I have heard of others who have connected into the socket using spade terminals. IIRC Haynes shows the connector socket and colours in their wiring diagrams.
i fitted a towsure towbar to my last 9000, the bumper didnt come off but you have to make a small cut in the bottom for the bar. this is hidden once fitted. the boot floorpan has captive nuts fitted so it just fits on - the towsure kit was well dimensioned and needed no swearing to position correctly.
as far as the electrics, i used towsures supplied lead that fits the cars loom and everything worked including bulb check.
total time 1.5hours, and much better than a parking sensor
hope this helps!
Originally posted by AlanG:
[qb]I connected to the wires going into the socket with scotchloks [/qb][/b]
Yeuch! Scotchlocks are NOT suitable for use in cars. They tend to corrode and become poor joints after time. The best method of joining wires is either to use crimps with a proper ratchet crimper or twist together, solder then self-amalg tape or heatshrink.
thanks guys. I was just getting concerned because Towsures sells the bypass Relays for cars "with bulb failure monitors" etc which got me thinking if I required one. Should get the towbar delivered in the morning and will fit it tomorrow night. Hope it goes smoothly, don't want to be out all night in this weather!
