1 - 9 of 9 Posts
I own a 91 9000 2.3L turbo and was thinking about installing "tornado air" in as seen on TV. I was wondering if anyone has heard of it or installed it on their vehicle and can tell me if it is worth it. Is it bad for the turbo?
thank you in advance
Marlon
Hi Turbosaab,
Had a look at http://www.tornadoair.com/ to see what it's all about - and , nope, wont make a blind bit of differance on a turbo car.
It will only effect normally aspirated cars (and that's debateable).
As your turbo is in effect sucking in air and the max volume of air is determined by the size of the air intake.
You would be better off spending your $'s on a free flowing air filter from JR or K&N or such like.
BTW welcome to the board.
Damian
Wow! 10-24% improvement in fuel economy! Makes you wonder why something similar isn't built into the induction system on all cars. Surely it would be a lot cheaper than highly sophisticated electronics and lean-burn engines that only give a few percent gain...
Hmm...
Anyway, I agree with DaMOB. Any "swirl" effect entering the turbo would be completely lost at the compressor. I can't see how it could damage anything, though.
Surely the place to put it would be between the turbo and the manifold, to produce swirl as the air enters the engine. Note, however, that the tornadoair website does not include the 2.3 turbo in their application list.
i think I saw a test of this on TV or in a car mag about 6 months ago. They could find no improvement, and in a couple of cases performance was worse. This was the unit inserted in the pipe and looked like a cut up beer can.
1 - 9 of 9 Posts
