Hello, I just bought an '86 9k, the owner said the timing chain had broke. I have not done a timing chain replecement before. I pulled the cylinder cover and the chain seems very tight from the top half. Could it still be broken? I would like to know before I tear into it.
How did you get the car home ie 'does the engine run?' is the obvious question - or even safer, what happens when you turn the engine over using a BIG wrench on the crankshaft pulley bolt?
Don't wish to be overly negative but VERY nasty (and expensive) things tend to happen to engines when timing chains break.......
Thanks for the reply, yeah, I don't have high hopes, I bought it primarily as a parts car, but if I can get it going, who knows. I have not tried to start it, I was told it didn't run, so I towed it home. Havn't done anything to it yet but pull the cylinder cover. I will try turning the crankshaft pully bolt.
