1996 2.0 LPT
Occasional whilst driving I notice that the Temp, EDU and fuel gauge all cut out and the fuel warning light comes on.
This lasts about 2-3 seconds and then they all return to normal. Speedo and Rev counter all normal. Happened once yesterday and 4 times today.
Not managed to find anything similar with the search facility.
Any ideas??
Mike J
1996 2.0 LPT
Any ideas??
Mike J[/b]
Mike, just been reading up on this but cannot find anything. the only thing I could tihnk of, BULBS, but that would not effect the temp & fuel gauges. it would however seem the the edu had turned off, no back light.
Mike,
What comes to mind is a poor earth connection or a loose edge connector on the back of the dash binnacle. Might be worth whipping of the top of the dash ( don't loose the 5mm washer on the drivers side ) to check for connectors coming slightly loose. Wiggle things about to see if you can reproduce the fault.
Paul @ Kippen.
