Hi, thanks for your comments. May I ask, was it just the light or was it the real effect of TCS, means just half power and part of the wheels braking at the same time. This is what happened to me.
tcs...
yes the light and the system can and does go into random limp home/lights on ..they all do that
I have two at the mo and they do randomly "throw a wobbly"
switching the ignition off and on usually clears it
If it does not you will need a tech 2 to investigate the prob
The Carly (just over 3 years ownership) has had 1 unxeplained and unrepeated tcs light over 2 years ago
The Aero I've had 9 years and it's had 1 intermittent (£15 check valve leaking backat -1 top -2 psi boost) and 1 limp home when the throttle pot failed.
Mine has been playing up as well. A sudden loss of throttle, so switch off & on again and away we go until next time. I think I've found the fault A small vacuum pipe under the throttle housing had come off. Since installing it the car has run much better (no false air) and the tcs has been behaving itself
The TCS system is intimately linked to the ABS system, so a fault in the ABS system can manifest itself in the TCS system. Logic, no?
I had problems with the ABS system which involved both dirt build-up on the front ABS sensors and also poor contacts between the ABS main relay pegs and their sockets. I cleaned the sensor faces (a ten-minute job) and ran a fine film of solder over the relay pegs to thicken them up. Poor contact problem solved. You might also care to check that the sensor cables are in good condition (they have to be) and that the sensor cable connections under the false bulkhead are still firm. All are quick and easy checks to do
