I WOULD LIKE TO KNOW IF IT IS POSSIBLE TO DISABLE TCS ON 1992 SAAB 9000CSE 2.3 TURBO AUTOMATIC. I HAVE HAD NOTHING BUT GRIEF FROM TCS SYSTEM TRIED CHANGING ECU CALIBRATES FINE FOR A SHORT PERIOD THEN KICKS OFF AGAIN I,M STARTING TO LOSE THE PLOT HAS ANYBODY GOT ANY SUGGESTIONS WOULD BE GRATEFUL
REGARDS
DARREN
Dazangie,
The TCS is an integrated system that is difficult top remove.
I assume your's is going into limp home mode? or do you mean it keeps cuting in when is shouldn't?
If it's limp home, do a search down the 9000 board over the last 30 days or so and there should be some good hints on which vavles to check, and which connectors to clean up which may get you going.
If it's not these, then it could be the throttle pot, and worse case senario, throttle houseing (many £££).
PS, welcome to the Saabscene.
