The light came on and will not go out, I have tried to reset, by unhooking the battery, no luck, the car is in limp home mode. There is not ABS light on and the ABS system is working. The check valves are all working. Am ideas other that taking it to a dealer.
I am afraid you will have to take it to dealer so that he can pull the fault codes..
only then you will knoew how much its going to hurt
it could be many things but the ets sounds favourite if the brakes are ok...
good luck !!
