1 - 1 of 1 Posts
I am also the proud owner of the tcs/abs system and it has been problimatical..(understatement!!)
as I understand it the tcs/abs system ecu is one unit which controls the abs/tcs hydraulic master cylinder set up
Ther are some relays in the system which can cause probs
I would imagine if the car has laid up for a while then some /all of the contacts might have coroded
first port of call would be to whip em out and clean them up..
after that the relays themselves may be dicky
(mine are !!) however these are expensive to replace
If you are near hatfield I can reccomend two stroke to turbo who seem to be very knowledgable about tcs/abs maladies
1 - 1 of 1 Posts
