Th interior lining to my sunroof appears to have come unglued / unclipped at the R/H end, causing the lining to wrinkle.
Anyone know how to access the lining panel, which I think should be removable ? Any clues would be appreciated....
Hi Chris,
Yes - the lining does seperate from the main roof (I assume it's a factory fitted metal one?).
The technique starts off by sliding the roof half back, then pulling down at the leading edge of the lining. THere are two metal clips which hold it in place with the metal roof. The rest of the instructions are a bit hazy, but I can send you a PDF file of the instructions - if you mail me at [email protected] .
I need to do mine as well, I'm think that PVC glue is suitable - but don't quote me...
Phil.
Many thanks to Phil for pointing me in the right direction. I have now done this job and made some further notes on how to do it if anyonelse needs them.....
