Has anyone ever had to change one? looks like an 'interesting' job & will have to change one to save my ears from a beating if i dont do it soon.
Its on a CDS with a steel sunroof 89MY'
thanx in advance
G.
I'd be interested in this one too since mine (glass 97MY 2.0t CSE) is currently taped up to cut down the awful noise above 55ish
I think the problem is mainly at the corners where you can feel the air rushing out when the ACC fan is on full and all the doors/windows are shut.
I was going to give it a try with some neoprene draught sealant tape (when the frost is gone) but would prefer to do a "Proper Job"
Dave
RK1340,
Just been quoted from SAAB for the seal + tape on the steel sunroof £98 +vat
The seal on your GLASS s/roof has a different sealing setup: 1pce on the front 1/4 of the s/roof, 1pce on the rear 3/4 of it with the joint
just behind the front corners,both the steel & glass share a seal which is located in the 'big hole' (good technical description ) between the roof & headlining,this could be where the noise is coming from
G.
