Well the Aero I bought a few weeks ago with a recently rebiult gearbox is now stuck in first
Just got back home via the RAC.
Its stuck in the gearbox - any ideas?
Is the Aero box different to or the same as a 2.3T, its a MY96.
Is it a good idea to try to remove the box and look inside? Car is stuck on the drive at the mo. Oh the very limited warrenty that came with the car only covers the first £250
Hi Andrew, no I can not select other gears - it is stuck in first. Can drive forward in first no problem, clutch works fine but the selector rod will just not pull it out of first!
Good luck Adrian, I hope it is not too expensive.
My car recently stuck in third gear, but was fine after shutting off the engine for a minute.
I have now driven 300 miles since then w/o incident. Am I on borrowed time?
