Does anyone have an idea what a strange noise coming from behind the glove box area may be?it sounds like when you turn the acc off and you get a rotating sqealing sound from the temperature sensor.It only happens when you accelerate.The car is a '95 9000 aero
Hmm well since no-one else has responded...
It's really hard to describe noises in BB posts, but when you said squealing I thought "clutch". My clutch squeals a bit sometimes, and I've been advised that this is probably nothing much to worry about.
I've never heard a squealing noise from the temp sensor: mine makes a buzzing noise I also get a buzzing noise like this from the glove compartment area when accelerating, and this I think is caused by the gear change linkage - either a problem in the linkage, or worn engine mounts. That was the second thing I thought when reading your post.
Hopefully one of these might be an approximation of useful for you
Thanks JohnCC,I have had a recent gearbox conversion so all parts should be new.I also had the engine mounts done,well at least I know the top one was done.Have to go back to dealer
