Hi all, just bought my first Saab - 1990 9000S 2.3 - after my Merc died. It has 150k on the clock but a full history including a £750 service at Christmas.
Soon after collecting it I noticed a "coolant"-type smell but no obvious signs of leakage. Next day I found a dribble of water on the passenger rubber floormat. I found the felt pad above was wet and removed it to dry. Examination with a torch showed water coming from the sleeving round what looks like the rear washer feed pipe. Now the washer bottle does seem to get hot from the radiator, and it does contain an additive, which might explain the smell, but it doesn't seem to leak when I operate the rear washer! Significantly here no water emerges from the washer jet. The pump for this does work, but if I take the pipe off the water just flows out of the pump outlet even if the pump isn't running.
Any thoughts? The pipe, sleeved as it is, looks a swine to access.
Also, now it's started raining, I seem to have a leak on the rear parcel shelf, almost above the speaker. Again, any thoughts on where this is likely to be from?
