Hi all,
Right ill start with the history:
had a collision about 3 months ago, most of the front end was wreked including all the rads, bonnet bumper lights etc etc.
As the accident occured only a mile or so away from home I drove it back very gently.
Due to finacial dificulties and the fact that I only had TPFT cover I have only recently started to put it all back together.
While the car was not driveable I also removed the heater plate from the manifold and cleaned the throttle body.
Yesterday I flushed the cooling system (see yesterdays post with regards to leaking rad) and put some injector cleaner in the tank with about quarter of a tank full of petrol, and all was fine, car run perfectly idling correctly with minimal variation in rpm.
I also put some rad seal in last night and ran the car for 10 mins.
This morning I started the car up to see if the rad seal had worked and the car Immediately started to idle at about 1800RPM so I left it for a few minutes to see if it settled (not sure if the removal of the heat plate may have had a bearing on it as it was a bit cooler and very misty this morn) But it didn't so first I gave the accelerator a quick nudge and it then started to hunt from about 2000 to 2500 rpm,I then turned the engine off and left it for a few minutes.
When I attempted to start the car again it was very lumpy and with no input to the accelerator it was idleing around the 400 - 500 rpm mark and stalled.
I have just disconected the battery to allow the ECU to reset while typing this, to see if it has any affect.
Other relevant info: the DI was new about 10 months ago and new plugs were installed aprox. 6 months ago, also at the mo the air con compressor is not connected due to no rad at present.
Does any one have any ideas as to where I should start to look?
I could to a compression test just in case I have blown the head gasket but I don't think that's the case as there was certainly no adverse pressurisation in the cooling system on the 3 occasions I have refilled the system.
I'm a bit lost here and really can't afford to take it to a Saab garage at present.
Please can any one give me some ideas?
Thanks in advance
Damian
Thanks in advance
Damian
