Hi guys,
I had a gig last night, and afterwards the tardis started misbehaving itself! In three very odd ways... :-(
Firstly, when you put your fut on the brake pedal, the sidelights and dash lights (but only in the instrument binnacle) come on! The brake lights also work and the pictogram shows nothing out of the ordinary. When you put the lights on properly, ordinary behaviour resumes, but when you turn them off it goes odd again.
Any clues where to start looking?
Also, on my way home the boost randomly started topping out at about 1/4 of the way along the orange bar... it felt quite a bit slower, but when I opened the window I couldn't hear anything out of the ordinary, either on acceleration or over-run. The boost gauge still shows vaccum on over-run and a bit on idle too.
Any clues for that one?
And the last thing is, the temp gauge is usually very well behaved and sits bang on halfway, more or less stock still.
Last night it would get to halfway and then very quickly fall down about a cm (to about 8 o'clock). Like a very sharp needle movement (enough to catch your eye when driving). Then over the course of about 15 seconds climb back up to halfway and then drop again. It kept doing this all the way back, even after I stopped, switched off the ignition for a few mins, and kept going. As if that'd help!
Any clues where to start for that one? The fan wasn't coming on to coincide and push the needle down or anything, and I was doing a steady 65 on the M3, so it wasn't even like I was speeding up and slowing down.
I'll have a hunt for topics about boost problems as I know there are plenty, but the others are a bit odd!
Cheers - Jules
Cheers - Jules
