I'm still getting a CEL when trying to start my car. I replaced the injectors which fixed this exact same problem before, but no luck. So I'm again... out of ideas. For those that havn't read my other posts, the car has died twice now when attempting to take it into boost. Hit less than 5 psi and just completely died after stumbling along for a second on 1 or 2 cylinders. Wouldn't even try to crank up again. As I said before changing out the injectors got it to start again, but attempting boost again killed it in the exact same way. Just thought I'd ask again if anyone had seen similar symptoms or anything. The local Saab shop is completely baffled, I've had them check over the wiring and such. Something is clicking over the main engine relay when attempting to start. I like the car a lot but I'm afraid I'll be forced to scrap it soon because of this. It's a sorry way for it to go considering the body and mechanical parts are like new, but what can I do it's a 3000 pound lawn orniment right now. Any advice appreciated.
EDIT : Forgot to mention... this time when I changed the injectors out (3rd time), it just gave me CEL and refused to start. Both previous times it ran and drove for about 30 minutes each time before I tried the boost, this time it wouldn't even start. Also I wanted to mention that the tac seems to be possessed (???) Every once in a while after resetting the ecu with key in 2nd position, the tac flips out and ticks around at 500-700 rpm... and something making a rapid clicking noise near the main engine relay the speed of the clicking is similar to the speed that the tac reads. No idea what that means, just thought I'd mention it.
