Saab 9k CSi (1990) - I thought I had a duff starter as it seemd to jam a few weeks back, and freed up when tapped. So I had a new one put in - but the same problem arose afterwards - which is that after a run to "hot", if I stop and turn off the ignition, it won't turn over on starting again, even a few minutes later. Full electrics are there, so no battery problems, just no response at all from the ignition - it doesn't even "click" or attempt to start. A friend fitted a bypass cable coming direct from the new starter motor and if touched to the battery terminal the starter fires up OK - so it's not the starter motor...... the fault is random and unpredictable.
Someone said "inhibitor switch".... what is this, could it be the cause of the problem, is it easy/cheap to repair ?
Thanks for any info you can offer.....
