when i start my 9000 xsi i sometimes have to try a 2nd or 3rd time as the engine starts to turn over then stops like it has jammed could the starter be dying or could it be the cable connections
thanks
Hi, it could be the pre engaged soleniod that is causing the problem. When it happened to me on another car, I stripped it down gave it a good clean and rease and all was fine, at the same time you can check the connections.Best of luck
